Thread: Question about narrowing
10-07-2008 #1
I have a friend who has a couple of 9 inches and Im looking into putting one on my 68. He has one that measures 48 and another thats 52 which one would be good to use on my 68 camaro if im wanting to put 335 tires. Also what rear set up should I use such as a 4 link? What would be a good combo to use. In front im using chris alston chassis and running a ls2 with a t56.
Also what size rim would work?
IF YOU DONT STAND BEHIND OUR MILITARY FEEL FREE TO STAND IN FRONT OF US!
-HOOAH-
11-05-2008 #2You can use whatever axle you want. I assume it is minitubbed already to fit that much rubber. The backspace of your wheels will make any axle work as long as the axle is at least stock length. What I did and what a lot of builders do is to pick out your wheels first, purely by what looks good and fits the wheel wells. Then build the axle that fits the wheels in the right location.
11-21-2008 #3
- Mar 2007
- 10
wheels
Order the wheels you want before you cut the 9" based on your offset
