Thread: Another motormount problem...
- Mar 2008
- Sparta, TN
- 37
Swapping from Oldsmobile engine to SBC in my 88 Cutlass.
Have the clamshells mounted in the proper place, per recommendations here and another site.
I do not know if I have...
A) the right block side engine mounts;
or
B) if I do have the right ones, I think I have them mounted on the wrong side of the engine.
We went to drop the engine in the car last night, and couldn't get the mounts to line up right. We got the passenger side to line up, but not the driver side.
Here are two pictures where you can see the block side of the mounts, and see they they are different.
Now, here you can see how they look in the car (in the same order):
Now... Here's what I was told when researching motor mounts for the engine swap... I was told that I could use the block side mounts from a 3rd Gen F-body. That's what these are supposed to be. A buddy who had one sent these to me.
What I'm thinking here is that I've got the mounts on the wrong side of the engine. I'm betting that if I swap sides, the mounts will line up perfect, you folks think I'm right?
10-07-2008 #2
- Mar 2008
- Sparta, TN
- 37
I pulled the engine back out last night, and can't find any real difference between the two, although the dealer says that there is usually a difference from left to right.
So, I'm not sure where to go from here. Not sure if I'm using the right block side engine mounts now. I guess I need to do some research.
10-07-2008 #3
- Oct 2007
- ridgefield ct
- 876
it looks like you have them right. they're just a f%^kin PITA! i fought with mine for awhile before they went.
10-07-2008 #4
