    Results 1 to 12 of 12
      Mar 2003
      South Carolina
      calling all welders.
      Can I weld stainless steel with my miller millermatic 175 mig welder?
      If so what do I need to do. I have a spool gun and control box set up already to also do alluminum, but haven't done any reall AL welding.
      69 Pontiac Firebird Convertible 400
      yes you can weld stainless with mig, nothing special needed other then stainless wire in desired diameter. you do not need a spool gun for stainless welding.
      Jan 2002
      Italy
      I just did my header tubes with stainless wire in my mig, I actually found it easier than normal steel due to stainless being more "rubbery"
      Have Fun!
      André
      2009 Chrysler 300C Touring.
      3.0 liter V6 diesel, five speed auto, black with light grey leather.
      1968 Chevelle Coupe.
      355cid, Viper T56, Corvette C4 IRS (Dana 44) and Corvette C4 IFS with Porsche 6piston Brembo's.
      1980 Chevy Van (shortie G10).
      355cid, TH350, 8.5" 10bolt posi and Belltech spindles.
      2000 BMW 540i Wagon. (FOR SALE €7K)
      4.4 liter V8, six speed manual, lowered and with Bilstein B8's, silver with black leather.
      2001 Ford Focus Wagon.
      1.8 liter turbo diesel, and a whoppin 90HP.:bsjerk:
      1968 Benelli Motorella
      foldable 50c scooter to go in a car trunk.
      2x '90s Yamaha TZR 2stroke bikes.
      one 125cc one cylinder and one will be 350cc two cylinder.
      I use tri-mix gas when I MIG stainless. 90% helium, 7.5% argon, 2.5% CO2. And you'll find you need more heat to get the same penetration.
      jp
      ​John Parsons
      Mar 2003
      South Carolina
      Cool thanks guys. I knew I wouldn't need the spool gun but it is nice for having a small spool and not having to change everything for a different metal setup.
      Kevin
      Jun 2006
      NW burbs IL
      Well I just welded my fstainless exhaust with the same wire and gas I used on the body. Well see what happens, I'll do a close inspection this winter when I have the car apart for upgrades.
      Matt
      matt that will work, it just won't have the properties of a good stainless weld
      Aug 2006
      [quote=Bow Tie 67]Well I just welded my fstainless exhaust with the same wire and gas I used on the body. Well see what happens, I'll do a close inspection this winter when I have the car apart for upgrades.[/quote
      It will rust from the bead outward...sorry. Also, to get a good stainless weld, you should use LESS heat... if the weld bead is grey or brown... you got it too hot... it should be gold or rose colored or it is too hot and will loose its stainless properties in the weld bead and the heat affected zone. (Carbide percipitation)
      You might want to post yopur question on the Miller Motorsports Forum (Ask Andy). Getting another proffesional viewpoint is always good.
      Its good to get opinions from proffesional weldors or at least someone who has some education in the matter. Casual hobbiests who teach themselves to weld can lead you astray quickly.
      Now...flame away
      polk county,FL
      A good stainless weld requires more heat than carbon of the same thickness.Stainless is more heat resilant than carbon.
      What parsonj stated about the gas is correct,but you can use 75/25(argon/CO2),it just burns hotter.
      a good stainless weld will also contain blueing on the outer edge of the weld.Not all of us are just hobbiest.
      Quote Originally Posted by TomV
      I find using less heat just leaves the weld sitting on top of the base metal. It hardly welds at all. I can't say I've ever seen a MIG stainless weld that was rose or gold colored either. As an amateur welder, I always want to learn more... got any pictures of a rose or gold colored MIG ss weld? I'd love to see one, plus any ideas how to get penetration with less heat with MIG.
      jp
      ​John Parsons
      Oct 2009
      Heat is the key to penetration.
      Sep 2007
      Thehoodstock,GA
      Quote Originally Posted by D Impala95 View Post
      That's what she said.
      MarkK
