      Aug 2008
      Daly City, CA
      750 ft/tq sub frame or solid frame?
      I have a ’67 Camaro that I am fitting with a LBZ Duramax. I have decided to use a t56 for a trans also; it will be built up. The power should be around 400hp and 750ft/lbs tq. I am leaving the diesel close to stock besides a tuner. The Camaro I have has a stock powder coated sub frame with Bear discs all the way around and is also air bagged w/ a 4-link. All bran new!
      Here is my question. What recommendations do you guys have on strengthening the frame? Could I use sub frame connectors and maybe some other aftermarket strengthening? Or maybe even build a full frame from what I have? With this option I could keep what I have and just add what I need. Or do I scrap what I have and just go with a Schwartz full frame? I am not planning on building a show stopper, just something to have fun with. All thoughts and recommendations are welcome. Thanks in advance.
      Tom
      cranberry twp pa
      your engine combo is SOOOO cool, i cant wait to see it run
      1969 camaro X11, Hotchkis TVS, GW upper/lower, 357 sbc, c5 Z06 brakes, Forged ZE wheels 18" front 19" rear
      Jul 2007
      Olathe, KS
      Considering the enormous amount of weight you're putting in the nose of your car, plan on a complete redesign of the front suspension. That being the case, it doesn't make sense to modify the stock subframe. To actually make this all work together will be quite a substantial project. I would feel a full frame would be much better suited.
      Is there any particular reason you're wanting to use the Duramax? Unless that engine is much lighter than I imagine, I can't see the car handling that well.
      Fife, WA
      We've done quite a few chassis for customers who are running Diesel power. The latest is for a 57 Caddy Eldorado Brougham(stainless steel roof car) with a twin turbo Duramax.
      This is definitely a project we can help you out with. If you want to pick our brains, please feel free to give us a call 800-929-7188 and talk with any of our sales and tech guys.
      Auburn, WA
      Quote Originally Posted by Rhino
      Believe it or not, it weighs about the same as a big block. It's not near as heavy as you'd think.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
