    Results 1 to 1 of 1
      Jul 2008
      Edelbrock 1st Gen Pro-Flow & LC-1 Wideband Integration
      I recently acquired a nice resto-mod and need some assistance installing an Innovate wideband O2 to work with the Edelbrock ECU so I can do some fine tuning. Please tell me if this is correct..
      1. Edelbrock O2 sensor harness has 3 wires
      A. Black is ground?
      B. Purple is ECU analog narrow band signal?
      C. Orange is engine running 12v?
      Can I hook up the LC-1 brown narrow band simulation to the Purple Edelbrock wire?
      Is the orange wire a switched 12v wire and if so can I use this as my power source for the LC-1?
      If black is ground, then I assume I can connect the LC-1 green & white wires to this?
      I would hook up the other remaining wires to the LC-1 wideband guage, ground, etc. What I want to do is simulate the narrow band output to the Pro-flow system and then also have the true wideband measurement so I can do some fine tuning.
