    Results 1 to 14 of 14
      Chicago suburbs
      SBC mechanical fuel pumps
      I'm looking to upgrade my current fuel system with a mechanical pump capable of supporting 500- 550 HP. I have a -8 line from the tank to the pump now. Any advise on which pump to use? I was thinking Holley's 130 GPH.
      Aug 2005
      stockton,ca
      The best mech pump for that power level is the Carter 172. I am running this pump with a sumped tank and -8 line all the way. Works killer!
      69 Camaro
      491BBC/TH400/GV OD/9"
      Chicago suburbs
      Carter 172 never even crossed my mind- thanks for mentioning it. Seems like alot of GPH though, I wonder if it takes more power to pump it? Do you run a regulator? Also, what tires are you running 11s on?? Thats another upgrade I'm doing soon.
      Jonesboro, Arkansas
      I have the Holley, seems to work ok. I've used one before. One thing about using a mechanical pump is that they are made to pump a certain pressure, you can adjust this pressure with a pressure regulator (duh!), but I've seen these pumps go out after a while, the thing to do is to use a regulator with a return. This eliminates the possibility of the pump building pressure before the regulator and pumping against itself, which will eventually do it in. I did this and it's no problem now...just my 2 cents.
      Aug 2005
      stockton,ca
      I dont use a regulator..it does not require one .
      I was running 275/50/15 MT DR's when I hit the dragstrip.
      69 Camaro
      Nov 2007
      crossville,tn
      Race Pumps has got any combination you need. www.racepumps.com
      Newbury Park, CA
      I had the Carter street pump (-6AN) and never had a problem even on track days. The engine was making around 450hp.
      Winchester, VA
      I have the Carter GM4891, here is the description from Summit:
      Higher volume for high-rpm driving.
      When you need powerful and dependable fuel flow, look for it from Carter. These Carter Strip Super mechanical fuel pumps flow 120 gph from 6.9 to 9.5 psi. They contain heavy-duty diaphragms, high-speed "anti-float" springs, large "full flow" valves, and lightweight all-aluminum castings. As with all Carter fuel pumps, they feature a tough, heat-treated lever. The pumps are available in your choice of natural or polished finishes.
      I've had it on 2 engines different engines since '01. On my 406, I was running my stock tank and fuel lines, no regulator, and no return line. I had zero problems with it. In fact, when the car gets put back together, I plan to use a fuel cell and new lines but keep my Carter mechanical pump. BTW, I'm making about 525+ HP and ran bottom 11's with it.
      Wayne Smith
      '70 Camaro - 406 - Street/Strip being converted to Pro-Touring (best 1/4 run - 11.05 @ 121, 1.50 60' - NA)
      '47 Chevy truck - 250 L6 / 5 spd - Resto Rod/Work Truck in the works
      Chicago suburbs
      I used a racepumps setup (pump & regulator) on a friend's mild BBC, and though I was way impressed with the fit & finish, the performance has been less than perfect.
      Oswego il
      Chevy Hi-Performance Feb 2009 just did a mechanical and electric fuel pump article.
      Apr 2008
      after i went to electrical i'll never go back to a mechanical on something i play around with. I love being able to turn the pump off
      Winchester, VA
      Quote Originally Posted by darkostoj View Post
      Why is that such a good thing?
      Wayne Smith
      Loganville, GA
      Quote Originally Posted by 70camaro406 View Post
      A couple of reasons
      1. If the carb starts to flood you can turn off the pump and sometimes (if you are lucky) the carb will clear the trash and work again. On the downside, if you forget to turn it on it can be a bit embarrasing (been there, done that).
      2. With the switch hidden, it makes it harder to steal the car or at least they won't get far. Randy
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
