Thread: Carb issue or Vacuum leak?
09-29-2008 #1
Made my first drive since starting the re-build last week - to the alignment shop. Car started running very rough and had no power at all. After the alignment, I limped it home. I've been chasing the problem all week and can't figure it out.
Here's what I've done (over and over again)
1. Checked all vacuum hoses for cracks, loose fit - good.
2. Checked carb over top to bottom, front to back - good.
3. Checked all wires/plugs - good.
4. Checked distributor cap, rotor, counterweights, springs - good.
5. Checked intake to head bolts and carb to intake bolts - good.
6. Disconnect vac hose to dist and plug hose - done.
7. Hook vacuum gauge to full manifold vacuum on carb - done.
8. Slightly loosen distributor to adjust timing - done.
9. Hook up dial-back timing light to check timing - done.
10. Start engine and let it warm up until choke is completley open - done.
>>>>>>>>>>>>Here's where I start having trouble.<<<<<<<<<<<<
The engine is idling at about 600rpm and acting like it wants to die, so I turn the distributor to get the rpms up to around 900 and it smoothes out.
I set the dial on the timing light to 12degs figuring that is a decent baseline to go from. As I turn the distributor to get the timing marks ligned up, the engine starts to stall again and vacuum goes to 10hgs. So I turn the distributor back the other way until I get a good idle again and vacuum goes to 14hgs. Curious to see what the timing is at when the idle is good, I turn the dial on the timing light until the marks on the damper and timing tab lign up again - the dial said 28degs!!! Mind you, this is without the vacuum advance hooked up! Why would it be so high?
Thinking the idle mixture screws could be part of the problem, I re-set the timing to 12degs and the rpms drop back to around 600 and the engine is stumbling, vacuum is back down to 10hs or so. I start leaning it out by turning the screws all the way in - one full turn per side at a time - idle doesn't change. So I start going the other way - one full turn per side at a time till it's waaaaay rich - idle still doesn't change.
The only think I can think of is it's either a vacuum leak, or the carb is not set up right. The carb is a Jet Products Stage 2 Q-jet that I bolted on right out of the box. I recently moved from Texas to Colorado, would my change in altitude make that much of a difference?
Also, just to clarify. My timing tab is the factory type with the tube on one end - at tdc, the timing mark on the damper should be directly inside the tube, correct?__________________________
Boyd
1972 P/T Style Chevy Short-bed - coming soon
Specialty Auto Services
09-29-2008 #2
- Sep 2008
- Calgary, AB
- 71
The first thing you need to do is physically find top dead center, and install a timing tape on your balancer.
This is the only way ti find true top dead center.
If you have an older engine, or a rebuilt engine, you must perform this step.
You may not actually be at 28 degrees initial.
09-29-2008 #3Thanks for the response. It can't hurt to physically find tdc and apply a tape, and I probably need to do it just to be sure, but I thought it didn't matter with a dial back light? Also, was I correct on the timing mark showing inside the "tube" on the timing tab?
Boyd
09-29-2008 #4
- Dec 2005
- 60
Take a careful look at your timing pointer, clean it up if necessary. I believe there is also a scale for use with a timing light. The tube is a receptacle for a magnetic timing probe and may not neccessarily line up with the timing light zero point.
Years ago, I had a scope with magnetic timing capability. It was slick, hook up the probe in addition to the other scope hookups and read the timing digitally on the scope at any RPM. The downside was that each manufacturer had their own offset that needed to be set into the scope before the readout would be accurate. As I recall GM's offset was -20 degrees, Ford's was -135, and Chrysler's was -10. There was a lookup table that had each vehicle's offset listed and some varied by year and engine.
As Mommy Wagon mentioned, verifying actual TDC is a good idea. Even with a dial back timing light, you still need to know your zero point. Again, take a good look at your pointer and be sure that you are using the proper scale.67 Camaro, 96 LT1, 4L60E
