      Aug 2003
      Wanatah, Indiana
      front runner heater hose
      I went to hookup my heater hoses today and noticed that I cant get to the nipple on the water pump. So I decided to take my compressor off and found out that it wont come off because the bottom bolt is on the back side and hits the cylinder head. Maybe I'm doing something wrong, can anyone give me some insight? Small block chevy with vintage air's front runner.
      Hi Mark,
      Did you get the heater hose problem squared away?
      If not, you'll have to remove the VA main truss bracket with the a/c compressor and alternator attached in order to attach the heater hose. Watch the clocking of the clamp to make sure it doesn't hit the main truss when it's re-installed.
      VA also makes a stainless steel heater hose outlet pipe "ëxtender" that brings it out enough so that the hose can be attached without removing the bracketry, it's part# 50101-SUR. This came with my VA FR kit for my BBC.
      John
      Aug 2003
      Wanatah, Indiana
      sorry it took me so long to reply. when i bought my front runner i was sold a longer nipple for the water pump. This week I am going to make a fitting and will post pics later.
      Jan 2000
      Thousand Oaks California
      Here is what I did
      Larry Callahan
      Metamora, Illinois
      What combination of fitting/hose end did you use?
      Quote Originally Posted by Larry Callahan
      Here is what I did
