Questions about SC&C's Street Comp Packages
I have a 82 Buick Regal......
Wanted to know about the SC&C Street Comp set ups..
Will they still allow the use of a 15x7 GN Rim?
If I understand correctly you can retain you stock spindle,and brakes and whatnot, but get the same effect as a B-body spindle swap,(the neg camber thing.)
The upper arm and tall balljoint alone, won't lower the front end, but in conjuction with the upper arm and upper tall balljoint, going to a tall lower ball joint will? also again can I still run my 15x7 GN rims?
If not just keeping the upper stuff, what front spings are recomended to help lower it some?
Luv my 4x4 front end? its rolling on 205/65/15 tires.
I got a 455 Buick in the front and heater delete...... the current springs I understood to be off a Olds G-body with a 307 Olds Motor.
Just looking to get it lower some better handling, I got the brake thing covered eventually going with SSBC Quick change Dual Piston Calipers, and stock size Big Bite Rotors, and their correct pads.
I got a set of used 245/50/16 tires for free...I know would clear bigger brakes just didnt want to go to the expense of bigger rims ( not yet)..just trying to be Budget minded and use what I got.
4.... 15x7 GN rims fornts ya know the size, the rears 275/60/15.
Thanks ahead of time
Later
Chris Reed
Vice Director of the Indiana Buick GSCA Club
"STG1RGL"
82 Regal (in 87 sheetmetal) w/Buick Big Block 455
(R.I.P. lost in my garage fire 01/09/14)
www.cardomain.com/id/stg1regal
7.5 G's Rule!!!
