    Results 1 to 9 of 9
      Aug 2006
      BBC hose from wp to maifold
      Bolting things back together and discovered I dont have the little 90 bend hose that goes from the intake to the water pump. Does anyone know where I can get a trick looking unit for that? Black preferably. TIA, Tom
      Los Angeles, CA
      Make you own with some -10 or -12 pro-lite 350 hose, and black or clear anodized fittings.
      Aug 2006
      Hmmm...
      You think it would bend that tight without collapsing? It would look good though. Thats what I used for the breathers to the exhaust.
      thanks, Tom
      Henderson,NV
      Small space for AN fitting. Ditch the hose. My engine builder said I didn't need it.
      Todd
      Aug 2006
      Quote Originally Posted by Vegas69
      OK... stupid uestion now... if its not needed... whats it for. Ive got an F1R intercooled 454 with 15psi boost/AFR heads... big power, big heat. Just want to make sure it runs properly cooled. I am runnung the 1000hp BeCool with the big dual fans... but I am warry...
      Henderson,NV
      It's supposed to supply your intake and thernostat with some flow from the factory. I don't have any problems currently with no crossover.
      Todd
      west michigan
      i never ran the crossover and i usually run about 180 in mine
      Aug 2006
      OK... Plugs it is.
      No need to spend money where its not needed.
      Thanks everyone!
      Tom
      Erie, PA
      Coolflex makes a nice bypass hose
      http://www.coolflex.com/cfm/store.cf...t=3&mode=parts
      Andreas
      www.fgmcc.com
