Results 1 to 12 of 12
Thread: Blown issues!!!!
Blown issues!!!!
I see 15" vacuum at idle when my boost vacuum gauge is teed of the vacuum line from my carb spacer to blow off valve.
I see 0 lbs boost when revved to 4000 rpm. (Gauge goes from 15" vacuum to 0lbs and then drops back to 10" approx.) Even when BOV's have been replaced by straight pipe and boost gauge is connected directly to carb spacer port.
I see boost referenced fuel pressure rising with rpm. So I tee boost gauge to line from regulator ro carb bonnet. I now have 8lbs-10lbs @ 4000rpm above the butterflies. But no boost below.
Procharger blow of valves never fully shut.
Do I have a leak? Could it be manifold to heads, Carb to Manifold.
I have -4 AN fittings from carb spacer to BOV, boost gauge, Carb bonnet, Areomotive 13202. I have checked/renewed connections from carb to vacuum advance, Turbo 350 actuator and from carb to brake booster.
AFR heads and Air Gap rpm manifold were installed by an autoshop with tons of silicone sealant visible. The rest was DIY installed.
Should I remove the BOV's (major air turbulace) and try the soapy water around the carb base and inlet manifold perimeter?
