    Thread: Need Help
      Sep 2008
      Need Help
      Hello,
      Working on a 2nd gen Camaro, getting an LS2 motor.
      I have a Friend looking to sell me an Accell Dfi Gen 7 would this be a good option for a stock LS2.
      Also what type of rad do I have to run I have a four core Aluminum Griffin, can it be used?
      Any feedback would be of great help.
      Feb 2007
      use the radiator for the sec gen the one you have will work great, as for the question not sure
      Brandon
      Sep 2008
      The reason I was unsure is I have seen LS2 rads with both inlets on the same side and a friend of mine put an LS1 motor in his car and he mentioned something about a reverse cooling rad that he had to buy.
      Aug 2003
      You can run a Accel, or a FAST, we sell both. But all you really need is a stock ECM, wiring and a tuner to tune it. lots cheaper. The Accel or FAST are better suited for high boost, crazy cam, etc.
      The both inlets on the same side is a double pass. You also need a steam line fitting
      Here is one we build
      Sep 2008
      Hello,
      What is the price, including the fans.
      Aug 2003
      $900 cmplete. I have another batch will be finished next week.
