      Feb 2002
      Santee, CA
      Custom Billet Grill
      I'm looking for someone that can build a custom billet grill for a 1969 Camaro. I want to take an RS Grill shell, cut out the center, and isntall a billet grill completely across the shell (over the headlights). Do any of you guys do this kind of work? or can you recommend a good shop? I'm located in Southern California so would like to try and find someone out this direction.
      Also, any legality issues regarding running a grill across your lights? I've seen several show cars do this, but not sure if I am asking for trouble or not.
      Thanks.....Eric
      Connecticut
      hey
      I do not know of a shop that does it but I know a place called chevyland.com makes one for 68's and i am pretty sure they have one for 69's something to look at. I think that it might draw attention from the law. atleast around where i am cuz they are pretty strict.
      Paul
      doesn't matter
      Try dan fink
      You might try giving Dan Fink a call. Check him out here http://www.hotrodproducts.com/grille_inserts.htm
      My webpage
      383ci, 10.4:1, AFR195cc CNC heads, Comp XE274R solid roller, Isky roller lifters, Isky rev kit, Comp pro magnum roller rockers, Comp stud girdle, Edelbrock RPM air gap intake, Holley 750DP, forged SRP pistons, Scat 9000 crank, Scat 4340 I-beam rods, Tremec TKO-600, McLeod clutch kit, McLeod scatter shield.
      CT
      Eric,
      I was thinking of making one this summer, exactly like you mentioned.
      If you get one made, I'd love to see it.
