      Feb 2003
      St. Louis, Missouri
      Saggin front springs
      I've got a 67 Camaro with 2" drop spindles(I know) and the original front springs. The car just sits to low in the front, I'm scraping the header flanges on everything. Question is, if I replace the front springs with stock(small block) springs, will it raise the front end? I'm quite sure it'll help with bounce, but will it raise it? I'd like to replace as little parts as necessary. Thoughts?
      Aug 2006
      Cibolo, TX
      Quote Originally Posted by Happyfunballs
      I run SPC spring spacers myself.
      http://www.specprod.com/CATALOG_DIR/Coil_08.pdf
      I had a spring I liked but needed 1/2 inch more height to avoid my front tires rubbing. The spacers worked great for me. I got them from Marcus at SC&C.
      Rob
      87 Turbo T: Precision 5857 Billet Wheel turbo, PTE Turbosaver, Razor's Progressive Alky, Red's XP fuel pump hotwired, Accufab AFPR, TurboTweak 93/94 chip, Scanmaster 2.1, 9 inch K&N filter, aluminum driveshaft, 160 thermostat, 3 inch Terry Houston downpipe with dump, DMH electric exhaust cut-out, TH 2.5 inch exhaust with Magnaflows, RJC powerplate, torque strap, Dutt neck stock intercooler, LT1 MAF, Translator Plus, Digi-Tails LED sequential tail lights, Eaton posi, TA Performance rear end girdle
      Simmons wheels: 17x8.5 front (4.32" backspacing) with 235/45/17s Vredestein Sessentas, 17x9 rear (4.75 backspacing) with 275/40/17s, SC&C Street Comp Stage 2 kit (adjustable upper control arms, Howe tall upper and lower ball joints, S10 Xtreme lower control arm bump stops), 13 inch Baer front brakes, S10 rear wheel cylinders
      Feb 2003
      St. Louis, Missouri
      Thanks for the reply, this just may be what I'm lookin for.
      Aug 2006
      Cibolo, TX
      I found a couple of pics so you can get an idea of what these spacers are:
      They fit on the bottom of the spring and right into the coil spring pocket in your lower a-arm.
      Feb 2003
      St. Louis, Missouri
      Very cool, thanks for the effort. I've got a new set of springs ordered and will see what happens, if it doesn't I just may go this route.
      Feb 2003
      St. Louis, Missouri
      Update....
      New springs helped a ton. Raised it about an inch and a half. Perfect ride height.
