    Thread: Twin Turbo Olds
      Amsterdam,The Netherlands
      Country Flag: Netherlands
      Twin Turbo Olds
      Doing some research on Turbocharged Olds engines. Planning to turbo an Olds 442, 455 engine. There is some info on Olds diesel engines on the net but looking for some more specific (finished) Olds projects. Any links/info?
      Cliff
      1968 Firebird
      Midwest
      We're in the same boat with our project S71 Olds... it's a diesel-block based 428 stroker with a single turbo and a FAST EFI system. Not much info out there, check www.realoldspower.com for some insight. Got pics?
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      We're probably are, not much info out there
      Got some pics have to search though, nothing special only a 442 without engine and rear end.
      Cliff
      1968 Firebird
      dayton, oh
      check out ROP. like kevin mentioned. most guys turbo the diesel small-block.
      what are you goals? do you just want a twin turbo? there might be a better way w/ your BBO.
      dave.t
      74 Javelin AMX - stocker
      We're looking in something totaly different. The old has seen several set ups; rebuild, stroked, steel heads, alu heads, lot of comp (13:1 on pump gas).
      With the twin set up we want to achieve triple digits horses.
      Cliff
      1968 Firebird
      Oct 2008
      If your looking to do a Turbocharged Olds motor, go with a small block for a base. This is what Im running, excellent durability.
      http://72.22.90.30/phpBB2/viewtopic.php?t=759
      Quote Originally Posted by TD2593
      Thanks Russel. I've seen your post on the Olds board. Do you have more details on the block maybe some pics?
      Cliff
      1968 Firebird
