Thread: Hurst shifter jams between gears
I have a new hurst competition plus shifter installed on a newly rebuilt Muncie M21 in a 1969 Camaro.
I have two issues:
1. Once in a while, if shifted quick, the shifter will jam between 2nd and 3rd causing me to have to really work to release it.
2. Trans will pop out of 3rd gear when I let off the throttle.
I have tried everything to adjust the shifter correctly. I used a nail to line up the hole before setting rod lenghths, I tried adjusting shorter/longer, I tried different washers/shims.
Any suggestions?
09-15-2008 #2The shifter needs to be adjusted with a solid 1/4 inch rod that fits tightly into the shifter base. Next make sure the shifter stops are out of the way when adjusting. Re-adjust the stop bolts after the rods are done. Lastly make sure the bushings on the rod ends are tight, and the retainer clips are putting good pressure on the rods to keep them centered. They sell the bushings and clips to re-build the rods. If you replace them, try and stay away from the plastic bushings.
09-24-2008 #3
New to Pro-Touring
- Jul 2008
- 22
Muncie
My Muncie M20 jammed on July4th and I had to be towed home. After that bad experience I ordered an Autogear super side cover with needle roller bearings - tighter tolerance than the original side cover case so that the shifting is smoother and more precise. Then took a couple of attempts to re-align the shift forks for optimal shifting. I have a shifter bushing kit but haven't had the need to install it yet since its running great now.
09-27-2008 #4
- Feb 2007
- USA, TN
- 850
Third gear popping out may not be a shifter problem. If the syncro keys and retaining spring are not installed correctly on the 3-4 pack, you will have problems with it popping out of gear.
