    Results 1 to 10 of 10
      CT
      Composite Headlights for 69 Camaro
      Where can I get replacement headlights for my 69 Camaro that use newer bulbs like an H4 or somthing??
      Also will need the plugs for them..
      Oh yeah.. I saw the DSE lights but was looking for somthing a little cheaper. Unless you think they are worth the money..
      Orlando, Fl
      Quote Originally Posted by skeeters65
      Ask and you shall receive. Both ECE (European code) and DOT approved versions are available.
      http://www.rallylights.com/hella/7in.asp
      Also, go ahead and relay them while you are upgrading. It will make a HUGE difference.
      http://www.danielsternlighting.com/t...ys/relays.html
      CT
      Has anyone used the HELLA lights??
      Do they fit the factory headlight buckets OK??
      Orlando, Fl
      I can't say I have used these, but they are supposed to be a direct replacement for a 7" sealed beam. I have used other Hella products and they are top notch.
      Des Moines, IA
      Our Velocity Camaro and the 2009 Goodguys SuperNova both use the 7" replacements from Rally Lights. The are made from real glass (no plastic here), fit perfect and work oh-so-nice. I run both the hi and low circuits off relays so as to not overload the AAW harness.
      They are MUCH brighter than stock, but don't require all the extra bits that HID requires.
      I'll be using them on every project we do unless I find something better.
      -Britt-
      Product Development Manager
      air ride Technologies
      Orlando, Fl
      Quote Originally Posted by marolf101x
      -Britt-
      Britt,
      Are you using the E Codes or the Vision Plus DOT lights?
      Nick
      Aug 2005
      Austin, Texas
      Britt - what wattage did you go with?
      CT
      He used the lower wattage..
      I just ordered the higher wattage setup..
      The guy I talked to on the phone was very nice and informative. You need to use relays for the higher wattage but the housing will be fine with the extra heat..
      I am putting a new harness in the whole car so that isnt a problem..
      Houston, Tx
      Which part number for these lights is everyone ordering? There are a lot of choices on their page.
      CT
      H6024N
      Is what I ordered..
      High wattage NON DOT approved..
      Those are Hella's best bulbs..
