      Mountain Springs, Texas
      Home brew paint booth
      I just finished building this paint booth in my shop and I thought it was worth posting in case someone else could use the ideas.
      I've been wanting a paint booth in my shop and was running short of storage space so I built the booth so that I could use the top for storage. It’s 14x22 feet and it's set it up to be a down draft style booth. There is a two speed fan on the top that pushes air into a 30”x16’ plenum that is lined with two layers of pleated furnace filters. The plenum opens down into the booth. The exhaust goes out through filters in the door. I originally planned a more elaborate exhaust system but I ran of of steam and went with the filters in the door.
      I painted the jams etc on my car this weekend and it seemed to work well. Overspray was very minimal. I even sprayed for several minutes before I realized I had forgotten to put my respirator on. The exhaust filters did their job and there was no evidence of overspray in my shop. I have a large fan that pushed air through the shop to keep the air moving.
      By going downdraft I avoided the need for an explosion proof fan and because it is a positive pressure booth there are no issues with dirt getting sucked in through any gaps or leaks. The fan is a 30 inch whole house attic fan that I picked up at Lowes. There is a total of 17 four foot light fixtures. The walls are lined with tile board.
      Don
      NY
      Very nice!
      Just a suggestion, not sure where the back wall is in relation to your shop, but maybe relocate the filters to it and another plenum, so you have no overspray in the shop.
      The needs of the many outweigh the needs of the few.
      The filters in the door seemed to catch the overspray. I don't want to cut holes in the shop walls. I'm only going paint at most one car per year and some parts so I don't think it will be much of a problem. I can change the exhaust filters every paint job if necessary. The original plan was a more complex ducted exhaust but I decided to try this simple approach first.
      Don
      Sep 2008
      Stonewall La.
      simple is good, Works for me. And I paint for a living, I've painted in a lot worse. Well, outside is about as worse as it gets, lol
      Nov 2007
      Paint both looks great, looks very bright. I set my garage up for something like that when I built it Just have never got around to actually building the booth. Mine usually consist of about $20 worth of walmart dropcloths wired up to the rafters encapsulating the car, then the "ahh it'll sand out method"
      Rural Retreat,VA
      I built a cross draft booth very similar to yours. I used Two 16" attic fans and used ceiling fan variable speed controllers to adjust the speed of the fans.
