    Thread: C4 13" brackets
      Northwest
      C4 13" brackets
      Does anyone sell the caliper brackets for 1st Gen camaro spindles using PBR cal and 13" c4 rotors other than Baer who want $300. I know there are a lot of c5 but I need the c4 style due to wheel size 16" V-45. Thanks, SS
      May 2002
      Northern California
      There are a couple C4 12" brackets availble for down load, just increase the bolt span by a 1/2" for use with 13" rotors. Wow, $300, I had no idea they were that much alone.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      May 2000
      I think both speedtech-performance.com and touring-classics.com sell those brackets.
      Northwest
      I know that touring-classics doesn't, only C5 and I think it is the same for speedtech but, I will give them a call. SS
      Nov 2004
      Seattle, WA
      Check out David Pozzi's Site. he has lots of info on C4 disc swaps including a template for a bracket
      Phoenix AZ
      We have the bracket for the 12'' style, and the calipers and the caliper bracket, Im assuming we would have to get the 13'' caliper bracket that the caliper sits in to increase to the 13'' calipers and rotors, or will the stock 12'' caliper bracket work with the 13'' calipers? If we need the bigger factory ones, does anyone have a set for sale?
      Nov 2004
      Seattle, WA
      My understanding is that you can use the same bracket (like the one on david pozzi's site) to adapt the drum spindle for 12" (JL9) or 13" (JL55) brakes. The calipers are also the same. However to use the 13" rotors you need to use a different caliper mounting bracket to get the correct offset for the calipers. Try http://www.gmpartsdirect.com/ for the caliper bracket. They may have it.
