Results 1 to 11 of 11
Thread: c4 irs experts - need help!
- Apr 2008
- 15
Hello everyone
so heres one for you guys
i have a 1990 bmw 3 series that i back halfed with a c4 vette suspension.
mechanically everything seems to have worked out perfectly - after 4 months of hard work
the problem i am having now is the car does not want to settle to a consistant ride height. When i layed everything out, i planned for a ground to fender measurement of 24 inches. I adjusted my coil overs approriately, and took it out for a spin.. next thing i know, the car is sitting at 26 inches.. back in the shop, adjust the coils and take it back out. everything is fine. park the car, pull it out of the garage and the car settles to an even different height.
i've never seen anything like this in my life. I'm currently running 400lbs springs, and swapped out to a 250lbs spring thinking the spring rate was way too high. The car felt worse with the 250s and the problem still existed.
My next thought was that the 'dog bones' or '4 link' bars were binding since they have poly inserts. So i now have the bolts on these loose to allow easy travel. The problem seems to be better, but still exists.
any thoughts on where to go next?
here are some pictures of the current setup. The rear is narrowed about 4" on each side - but that does not seem uncommon
i need help before i go insane over here :pain: :pain:
car sitting at approx ride height - maybe a little on the high side. I had only planned on having 1.5 inches on each side of ride height - 2" max each way
good view of all the mounting points
an earlier picture before all the components were in place
car sitting way way way too low before i had everything adjusted
