Results 1 to 9 of 9
- Feb 2005
- 134
Less lbs over the nose = better handling ?
Did'nt know where to put this question, perhaps the handling gurus can tell me if a first gen camaro will handle/ turn better with less weight over the nose. Is there a significant difference running an alluminum engine block versus an Iron block? Both small blocks either would have allum heads.
Thanks Rich
02-20-2005 #2heavy bats...
Yeah, any car that has less weight will handle better. Think of it as trying to swing a heavy bat versus swinging a light bat. It is much harder to swing the heavy one quickly...
The only thing that weight won't affect is top speed. Naturally it will take longer to accelerate but eventually the top end will be the same.
manuel scettri
02-20-2005 #3
- Jan 2004
- NW Suburbs, Chicago
- 560
The car will be more agile... It will be able to change direction faster. Its just about momentum, along with that bat swinging analogy, try swinging a heavy bat back and forth, and try swinging a light bat back and forth... you notice you can change direction MUCH faster in the lighter bat.
along with that, tires will hold up longer and there will be less weight transfer as there is less weight to transfer.
02-21-2005 #4
- Jun 2002
- Benicia, CA
- 1,433
