    Results 1 to 10 of 10
      Feb 2008
      help with cam selection bbc 427
      Hey everyone, I have a 427 bbc 512 block that will be going into my 69 camaro. I am running tremec 5 speed 3.73 gears, hooker headers 3". The pistons are keith black 9917 forged .030 .500 dome I think. The heads are oval port 113cc chambers #6272292, The compression is 11.06 to 1. The intake is edelbrock performer 2.0 with a 750 holley.
      Now with that all said, this is a pro street car need vacuum for brakes. I car will be running street and track 50/50.
      What do you guys suggest.
      Feb 2008
      The cam the builder put in it is crane 228 duration with .544 lift on a 112 lobe sep. I think this to small what do you think.
      Aug 2008
      11-1 with iron heads is going to give you problems.
      I do know a real L-78 396 with the late L88 cam can run on premium and limited timing and not detonate badly-cranking comp was 195
      With your high comp. and mild cam I would think 215 psi cranking comp-It will DESTROY your motor with any pump gas-Do you have E85 in your area?
      Feb 2008
      I dont think so on the e85
      Sep 2008
      Calgary, AB
      Cam is at minimum about 10 degrees @ .050 too small.
      I would try to be around 240ish intake and 248ish exhaust. Bigger if you want to go roller.
      Your compression and gears will make up a lot of bottome end. The overlap will also bleed of some compression.
      I would also swap intakes. At minimum I would go to a Performer RPM. For my own car, I would go Victor. My personal opinion also is you need an 850, but I like carb work and adjusting.
      Only ideas, let me know your thoughts.
      Feb 2008
      I have decided to go with a howards hydraulic roller cam, duration @50 is 236/242 with .620 .620 on a 112. The Lifter and the roller race rockers are Crane. I have also gone with Patriot heads 320 intake runner with a 121 chamber which will give me 10.8/1 compression. The intake I went with a dual plane air gap, as for the carb havent decided yet, but most likely a 850 or 950.
      Sep 2008
      Calgary, AB
      EAS69, That sounds like VERY strong combo!!!!
      I am excited to hear how you like it, that cam should sound great.
      Good luck
      Feb 2008
      I got the cam installed to night. Everything went as usual, the rest tomorrow night. Will let you know how it sounds. should be good for 600 plus horsepower and torque.
      Sep 2008
      Calgary, AB
      DAMN YOU! what kind of a tease is that........
      Call in sick, get it running, inquiring minds NEED to know!
      Feb 2008
      Quote Originally Posted by Mommy Wagon
      Ok sorry for the delay. I got the sucker put together, and it fired right up. All I have to say is WOW, this sucker sounds great.
