    Results 1 to 14 of 14
      Aug 2006
      San Francisco, CA
      ATS Lee 670 Steering Box vs. Header
      Oh man, today's been quite a day...wheel studs too short, antifreeze in the oil, and impossible to install this steering box:
      Im swapping out my manual box with the ATS / Lee 670 box on my SBC 68 Camaro, I can't see a way to make this work wth my Dynomax 1 5/8" headers, Pro Topline aluminum heads. I even hammered the header quite a lot, just to say I tried that.
      Any advice? Anyone have headers that work with this box? Thanks a lot!!
      Steven
      1968 Camaro: Project "TRACKDAY"
      Latest Track Weekend Video
      Build in Progress
      Oct 2007
      take the out the header, Put the box in then bolt the header to the motor with it jacked up. The lower the motor slowly.
      Aug 2006
      San Francisco, CA
      Thanks for replying xLexusTech. However, I don't see how I could lower the motor back down without the header coming into contact with the box. The pictures show the steering box in the proper position, and that the header is currently tilted inboard on the 1st and last header studs, with a 1/2 gap between the head and the top of the flange. The header is already hard against the box in this position;closing that gap would definitely mean that the header and box would be occupying the same space.
      Steven
      Build in Progress
      header fitment
      I have a 92 IROC steering box on my 69 Camaro and the only headers I could get to clear the steering box is a set of Headman
      headers. They have a lot of clearance which is hard to believe.
      Call Hedman and talk with Chris about the correct part number.
      Billy
      I took the top right bolt out of my steering box which allowed just enough room to get the header on. Wasnt enough room to put the bolt back in, so i just run it without one with no leaks. If it every leaks I will just weld the top on.
      Jun 2008
      Oklahoma
      I cut that tube out and flipped the section of tube over then fitted it up and welded it back together, with the bend that section has you can get some clearance. My headers aren't coated though and it took some heat to tweak the lower part of the tube up slightly so you make up for the saw kerf.
      Henderson,NV
      You can screw around forever with header fitment or buy a set of Lemons for twice the money and be happy for life. I don't like taking headers in and out so I would beg, borrow, and steal for a set.
      Todd
      Aug 2006
      San Francisco, CA
      Thanks you guys for your help. The Lemons or Stainless works headers will be an option if the next set I buy doesn't fit...
      Quote Originally Posted by morrisclassic
      Billy
      Thanks Billy! I spent a ton of time searching on camaros.net, and many people are running the hedman 65003 / 66003 (coated) headers w/ good clearance to the power steering boxes. But they complain of having to dent to other areas, specifically to clear the nut of the ps box. Is that the header you used (1 3/4") and did you have to do any "clearancing?"
      What I have found so far from camaros.net
      Hedman Hustler 65003 / 66003 (coated)
      --Should clear the box but some report having to bash them up to make them work...others with perfect results
      Doug's Headers D368
      --Remarkably similar to the Hustler but far fewer complaints of having to bash them up. Much better reviews
      Anyone for or against these headers? I'm strongly leaning to the Doug's right now...
      Steven
      Build in Progress
      Oswego il
      Quote Originally Posted by sik68
      They will occupy the same space, the header will "form" around the steering box, might help to put some button head bolts in the tightest area.
      Header fitment
      I didn't have any clearance issues. I have the 1 3/4" headers. Can't remember the part number. Call Chris at Hedman Headers.The only issue was that I had to have the car raised up in the air about 2 feet to install the drivers side header from the bottom and had to remove #1 spark plug. Well worth the money, no hassle install or removal. Also these headers set just below the subframe instead of hanging down and dragging on the road. Billy
      Sep 2001
      Accord, NY
      My old 65003 fit perfect. The new 65003 ones had to be sent back.
      68 camaro - SOLD
      Northwest
      S&S 5215, is really tight by the box but it fits! Not sure if my box is 600 or 800 series though, done by Lee years ago!
      SS
      Aug 2006
      San Francisco, CA
      Hey guys! Thanks for all your help. Just to pass on an update about the headers and give some closure for future searches, I copy/pasted from my buildup thread:
      My new Doug's D368 headers! And they clear the power steering box! Man, these are quality pieces compared with my Dynomax headers. Doug's top, Dynomax bottom.
      For my mockup install, I had the car on jackstands front and rear, and the steering box was not in. I put the header in from the top. Then I covered the primaries with a rag, and could actually put the steering box in from the top and completely bolt it in. The clearance isn't enormous, but it could be enough since the motor torques to the other side and I am running solid body bushings. Here are some pictures of the clearance:
      The clearance is actually a bit more everywhere than these photos show, it's just hard to get a photo that shows the true gap between them. Finding headers that fit is a true victory. I didn't try the passenger side header yet.
      Oh, and for the record, here is a photo of the driver's header and how far it hangs below the subframe: Roughly 1.5"
      Steven
      Build in Progress
      May 2009
      Florida
      Put the Lee box first then headers and hoist motor up
