Results 1 to 9 of 9
Thread: tire help
09-06-2008 #1
tire help
I just got my new wheels, now im in search for tires, Im set for the fronts but need some advice on the rears... they are 19x10... I really want a 305 series tire but i dont think its recommended on a 10 inch rim?? If I cant get the 305 I'll go with the 285... anyone here run a 305 on a 10 inch rim without any problems? do they bulge out? any pics would be great also
09-06-2008 #2I say go for it! Some people might say that a 305 is too wide for a 10" wheel, but i've seen 9" wheels with a 295 and it looks and fits fine. I have 18x9 wheels with 275/40s and i am going to upgrade to a 285 when i need new tires. i think the average size tire for a 10" wheel is a 285. I'm sure others will chime in here and give their opinions as well.
Roger
09-06-2008 #3You can fit up to a 315 on a 10 with no problem and you'll just have a nice bulge on the sidewall.
Jason
09-06-2008 #4Im looking for a 305 but cant find many options with the 19's I have... I wanted a 35 series for the rear 305 but can only find a Nitto 30 series (I wanted a 35 series) and i wanted a 40 series for the front.. I dont know if I want to go 40 series in front and 30 series in the back seems like too much diffrence... any suggestions?
09-07-2008 #5I know what you're saying and have had similar frustrations and it's simply because that's mostly a supercar size and they have little need for much sidewall with the exception of the Ford GT which ran a 315/40/19 which looks killer if your wheelwell can hold it. If you don't quite need that much, there's a nice BFG 295/35 that will get you really close to your height and width needs.
Here's a wheel/tire size calculator that is really handy for quickly comparing front and rear sizes but as a rule of thumb, be sure your front sidewall isn't bigger in inches not aspect ratio than your rears or the car will always look like it's going uphill.
http://www.rims-n-tires.com/rt_specs.jsp
Depending on your front width, the 40 series may be really close in sidewall height so don't instantly discount it because it's a taller aspect ratio.Jason
09-07-2008 #6Thanks for your help JayR, I appreciate it! Yeah I knew when i bought that I might get into problems with the 19's because theyre mostly on BMWS, Porches etc... but i knew what i was getting myself into and i wouldent have it any other way... anywho, the BF KDW looks good but its a bit more then I wanna spend...I might get the Nitto Invo but to get the 305/30/19 in the rears ill have to get the 35 series in the fronts otherwise the front tires will be taller, plus I dont feel too comfortable with 35 series in front... the other option is to get the Nitto's in 245/40/19 Fronts and 285/35/19 in the rears that sounds more comfortable to me.... BUT I want those big 305's LOL, anybody here running 30 series tires? would you? this will be driven almost everyday....
09-07-2008 #7I hear you and as a designer and a wheel guy, I totally respect making certain concessions to nail the wheels and stance because it's the two most important things!
Jason
09-13-2008 #8
