      CT
      69 Camaro w/LS1 Exaust ???
      I am looking for pics of your system with this setup.. Has S&P headers with minitubs..
      Will anything aftermarket work or does it all need to be custom??
      Jackson Ms
      custom
      Chris V
      SOLD
      florida
      I have the same car.in the process of installing exhaust.Ive got a magnaflow 2.5 inch kit.kit will work right up to the rear end and then your on your own.I like the kit due to the nice oem style hangers and the x pipe.
      CT
      Mark,
      Is your car an LS1??
      What headers are you using?? What did you use for down pipes?
      florida
      Yes mine is an ls1.I used hooker supercomps with a 3 inch collector with the o2 sensor bung in it.my exhaust is 2.5 inch.like i said im pretty happy with the magnaflow system.if your car is tubbed you will need to bend all new pipe from the mufflers over the rear end.also if you havent already bought your tank i highly recommend having the front corners cut off for more exhaust clearance.
