      Welding a drag link
      is it feasible/practical/safe to consider cutting and welding a drag link/ center link. I'm looking into feasibility for narrowing the track on a 67-72 chevy C10 front end and for that to be an option the center link would have to be narrowed also. The stock factory bar is forged isn't it? Is this a bad idea?
      Thanls
      A
      IL/TN
      it should be forged so it can be welded but I would sleeve it
      https://www.protouringf-body.com "doing what they say can't be done"
      Weld the cut ends together then slide the sleeve over the join and weld the ends to the bar? Should I plug weld through holes in the sleeve to get extra weld surface area?
      Central CA USA
      I've seen circle track center links welded and gusseted, also Global West sells a center link with relocated inner tie rod sockets.
