      Aug 2008
      T5 Transmission for SBC help please!
      Hi all,
      I am going to start mounting up a chevy small block into my truck. Now the problem is, the shop (the guy) who will be mounting and setting up the engine and trans has the block, a th350 tranny, and everything else we need to mock it up. but my problem is that I want to run a manual trans, and not the th350.
      The t56 trans is pretty much out of the question because I simply cannot afford to dump more money into the engine and drivetrain, but also I am afraid to use a t5 because everywhere I look it up, its rated for about 300 ft/lbs of torque (or less). The motor will be making atleast 350 ft/lbs easly from our estimates, so I am afraid that I am going to have a problem with this.
      Does anyone know where (or if i can even get) to get a t5 trans that will be able to handle up to 350 ft/lbs. This truck will pretty much be a show truck, with some light weekend driving so I will definetly not be beating on it. Also does anyone know a good place to get the bellhousing and adapter for the small block (this is the first generation small block).
      Thanks for everyone's help!
      North Jersey
      If you want to use hydraulics for the clutch, then an '84-'92 V8 Camaro/Firebird bellhousing will work for you. If you locate a good World Class T5 ('88-'92 V8 F-body cars had them) they can be rebuilt with parts from Hanlon Motorsports - http://www.hanlonmotorsports.com/ - or you can probably buy a built one from them. Honestly, if you're not going to really beat on the truck, or use sticky tires, a stock T5 will probably hold up just fine. They usually break when powershifted, or using sticky tires at the drag strip.
      As for mockup purposes, if the guy can get a hold of a 700-R4 trans from an F-body, you'd have the tranny mount in the right place and you'd be able to figure out your driveshaft length as well. Good luck!
      Steve Ragusa - North Jersey
      2006 Infiniti G35x
      Aug 2008
      so the 700 r4, will be able to pretty much simulate the t5 trans/bellhousing? the driveshaft is not really the issue right now, its more the floor.
      We will be building a brand new floor, firewall, and rear cab wall from scratch and I would not wanna do it over twice.
      If the 700r4 will work for mocking up purposes and has the same basic dimensions that would be killer, because the hotrod shop might have one laying around. can anyone confirm that this will work for mocking up purposes? Thanks all!
      Midwest
      Well, the 700 fit the floor of the F-body just like the T-5 did, so you might assume that the 700 would be a good mock-up unit. You'll still have to figure out the shifter hole, though. There are used T5s on craigslist and stuff cheap - maybe get a junk unit for a few bucks to mock up your driveline, then sell it and use the cash towards the World Class unit when you're ready.
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      Aug 2008
      Good news!,
      I spoke with D&D Performance, and the t5s they sell are all built to withstand up to 400 hp. I called the guy and asked him if he could send me the bell housing and tranny case for mock up purposes. He said yea for $400 he'll ship it to me, and then once i'm done I'll just ship it back, and have them credit me the money towards a new trans.
      The new trannys they sell are around $1200 which is pretty good I would think for being able to handle the power cost effectively.
      North Jersey
      Very nice, good to hear! Good luck with your project!
      2006 Infiniti G35x
