      May 2006
      gear vendors + 4l60 + compushift???
      i have a 4l60 with compushift and twist paddle shifters... will it work with a gear vendors OD turning it into a manumatic 8 speed doule overdrive???
      thats "Doctor Deuce_454" to you!
      79 Malibu 2dr "Malice"
      Heads & Cam LS1 / 4L60e
      twist paddle shrifter
      ATS / global west front susp.
      Currie CA's / SC&C wattslink, Moser 33 spl rear susp. 3.73 gears
      18x8.5 and 18x9.5 forgeline WC3´s
      boxed frame, solid mounts.
      touring classics / bear 13 & 12 inch brakes
      hydraboost
      12:1 lee steering
      full leather
      vintage air
      Jun 2005
      I think you'll be alternating between paddling and button-pushing. Why would an 8-speed be desirable on a nice, torquey motor?
      Jim
      Half-Assed = Half-Fast
      call steve at twist machine, i think his sema car last yr had a 4l80e with gear vendors
      Jan 2003
      Arizona
      The two systems are completely isolated, so yes it works. Just need to decide how to actuate the GV. Your paddle shifter has two channels: Upshift and Downshift. W can build paddle shifters with up to four channels. Or we can provide a Sparco steering wheel with momentary style push buttons and you can use the horn wire to actuate the GV.
      I am with Jim in that I feel 8 speeds are unnecessary. For example I raced around the entire Road Atlanta track, lap after lap, using only 2nd and 3rd gear. Remember that we have semi-viscous couplings, so close ratio gear changes are not as critical.
      That's not to say that the GV can't be fun. I would use it with the mechanical shifter in "3" as a six speed.
      ________________
      Steve Chryssos
