    Thread: ls1 question
      St.Anne Il
      ls1 question
      ok i am looking at a 2002 ls1 corvette car today that has a bad motor..if i get it can i swap in any ls1 engine from that year or will it have to be a corvette engine?..i didnt know if computer would know specs on each engine or is it easier to have this one rebuilt..?...thanks
      Darrin Stalnecker
      2007 Corvette Supercharged
      1968 Camaro LS1 T56
      Jackson Ms
      rebuilt? that depends.
      do a little research but any ls1 should drop in. you may have to get a tune $400-600 and you should be good to go.
      the heads/intake/cam are different on the vette
      Chris V
      SOLD
      Aug 2006
      Not positive, but I believe that the 'Vette motors do not have an EGR system, while the earlier F-body motors did. Not sure about the later F-body motors though. Also, in 2001ish all LS1's received LS6 intakes and a cam change. So depending on what motor you get a tune may certainly be in order. That's about the extent of my knowledge. I'm sure that someone else more in the know will chime in. Good luck with everything.
      May 2006
      just change the shortblock or whatever is spent, and swap in the corvete cam, if thats dead too get one that suits your fancy
      thats "Doctor Deuce_454" to you!
      79 Malibu 2dr "Malice"
      Heads & Cam LS1 / 4L60e
      twist paddle shrifter
      ATS / global west front susp.
      Currie CA's / SC&C wattslink, Moser 33 spl rear susp. 3.73 gears
      18x8.5 and 18x9.5 forgeline WC3´s
      boxed frame, solid mounts.
      touring classics / bear 13 & 12 inch brakes
      hydraboost
      12:1 lee steering
      full leather
      vintage air
