    Thread: Air Ride Kits
      Girard Ks
      Air Ride Kits
      Does anybody know where a good place is to buy a air suspension kit???
      north central Iowa
      Oct 2005
      Jasper,IN
      What kind of car are you working on?
      Girard Ks
      Well It is a 1959 Rambler wagon with a tube chassis, mustang ll front end, and a ladder bar setup in the rear???
      Oct 2005
      Jasper,IN
      Whose front end is it? Does it have a stud mount on top or eye? Is the lower arm setup for a coil spring or coilover? Is the rear already setup for coilovers?
      Girard Ks
      Its a stock frontend out of a 1978 mustang? Yes the rear is setup for coilovers.
      Oct 2005
      Jasper,IN
      I are wanting to swap to tubular arms or use the OEM arms? I would recommend at least using a tubular lower so you can use the Shockwaves. They will not work with the factory lower.
      Shockwaves should be an easy swap for the rear coilovers. Just give us a measurement from eye to eye at ride height. How much does the rear of the car weigh?
      Girard Ks
      I think i'm just going to run the stock lower a arms for now. I could not tell you how much the rear of the car weighs i have never weighed it.
