Results 1 to 12 of 12
Thread: Car dead, HEI problems..
08-26-2008 #1
I am having trouble doing the conversion from points to HEI on my 67 Catalina. All went well with the distributor swap and it started and ran fine while testing with the 8 volt wire that originally went to the coil. I then took that “resistance” wire and cut it one inch from the firewall fuse block, but it still measured 8 volts. I took apart the fuse block to trace the wire and it seems that on the interior side of the block, the terminal has a yellow and a white wire going to it. The white wire looked like it had some sort of cloth fibers under the plastic outer coating. This traveled up over the dash cluster and “disappeared” it seems because it does not seem to come back down anywhere. The yellow wire I traced to the ignition switch. I spliced into this yellow wire just after it comes out of the fuse block and ran it to the BATT terminal on the distributor. This supplied 12 volts with key on. It ran great. After driving to town it started hiccupping and I pulled over when smoke came out of the dash vents. Now, I can turn the motor over and it fires up great but as soon as I let go of the key it shuts down. I re-tested the one inch of wire I left coming out of the firewall originally and it now does the same thing?? I am thoroughly confused now. Can anyone help me out, thanks!
08-26-2008 #2If the color codes are like a Chevy, the yellow should only supply 12 volt power while cranking. The white braided wire should supply running voltage, 8 volts. You can pick up power at the fuse box and bypass the existing wires. Just find a wire hot, ignition only, and hook it up.
08-26-2008 #3The schematic I have would agree with that.. yellow to the soledoid. For some reason I was able to get ignition from that wire to run the car. Maybe it was being back fed by the resistance wire and that what I fried. Anyway, my schematic shows light blue for ignition hot, does this sound right with the Chev colors?
08-26-2008 #4It might be light blue at the ignition switch. I can't remember. The rest of the wire that you can see is a thin braided white wire.
08-27-2008 #5I'll tap the blue one tonight and see what I get!
08-27-2008 #6
