      Jun 2005
      Airover Leaf from Air Ride Technologys
      What do you guys think of this added to a F-Body ?
      You can still use regular shocks with the added benifit of an adjustable set-up.
      Anybody using these.
      http://www.hotrodsusa.com/store/air_airoverleaf.html
      Would be less expensive than shipping heavy steel springs.
      Indiana
      Since you are cruising this forum I have to assume that you want to optimize the handling and cornering performance of your Camaro/Firebird. The air/leaf system is not the best choice. That product is intended to give a streetrod type vehicle some ride height adjustability and added load capacity for a minimal investment. Those vehicles/customers are not concerned about turning corners at more than 10mph. Although the air pressures and leaf spring rates could theroretically be juggled enough to acheive a nice handling vehicle, a simpler more effective approach would be to install the AirBar 4 link system that replaces the leafsprings entirely. This system separates the functions of holding the rearend in the car and supporting the car, and is able to optimize both. I know it is more money...but you will be 8 times happier for what [I assume] you are trying to do.
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
      Jun 2005
      Thanx for your input, the Airbar set-up is wayyyy too expensive -$2200.00 or so.
      I was just looking to enhance my exsting springs instead of using air shocks.
      I live in Alaska so what I can do to help save on shipping is also part of looking into the AirOver leaf set-up, a small package.
      Jun 2005
      Update
      I had a good look at things today during my shock swap.
      There are the rear sway bar mounts and bumps stops all in the same area of the upper frame.
      Not a good option at all !!
      Rear springs look to be the proper way to go , not that I doubted anyone, just looking to save time and shipping cost.
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Quote Originally Posted by billz428
      You could have a look at some composite leafs, they weigh far less than steel ones and thereby do save some shipping costs.
