      Albemarle, NC
      nasty vibrations
      after installing what are supposedly belltech 3 inch drop leaves in the back of my truck, i have come across a vibration in top gear, cruising, at speeds of 50 or greater. its bad enough that i can watch the bed rock in my side mirrorrs. i have just finished measuring angles, and now im unsure what to do with them.
      i used an angle finder from lowes, and measured using a 3/4 short socket from the u-joint caps, with the cap being perfectly centered at the bottom of the driveshaft. the angles are:
      front, yoke: +4
      front, Drivehsft: -1
      Rear yoke: +3
      Rear driveshaft: -1
      and as far as the numbers themselves are concerned, my math gets me to + 3 front, and +2 rear. if what im reading all over the place is right, i wnat to bring my rear down to -3, correct? equal but opposite? so that would mean 5 degree pinion shims.
      am i way off base here?
      Michael
      Michael Crawford
