Results 1 to 13 of 13
Thread: Sorta PT, my daily driver build
08-20-2008 #1
- Mar 2003
- Petaluma, CA
- 412
When gas prices hit $4/gal I decided I needed something that got a bit better gas mileage. I searched for a while, it seemed everything in my price range ($3500ish) was either super high mileage or severely beaten. Anyway, a friend of mine suggested that a datsun 510. I wound up finding a half finished project car in my price range.
Specs on the car are:
rebuilt L20B with a mild cam, header, Webber 38/38
new centerforce clutch,
rebushed close ratio dog leg 5 speed,
Subie LSD with 3.54 gears,
rebuilt front end, bump steer spacers,
280Z front struts and brakes modified with 510 spring perch weld on, Suspension Technique springs,
240Z finned aluminum drums,
staggered panasports with new tires,
new interior, etc etc etc. just lots of new stuff, it just needed to be put together.
However, I did not like the color, and that snowballed into a major rebuild.....
Here it is when I picked it up
Then I got carried away with the sanding and took it to bare metal and found all sorts of interesting things.....
So I got the body work finished up, and primed and blocked. The painting has started and is nearly finished. The car will also be de-chromed (all painted satin black).
Hopefully I will be able to pull down some decent mileage with it.
