Results 1 to 19 of 19
Thread: 2nd gen camaro upgrades
New to Pro-Touring
- Sep 2007
- 49
Anyone here know of any kits or packages for upgrading a 1971 camaro too a rack and pinion steering system.Also if not something already on the market then any ideas what kind of racks might be adaptable to my frame.The main consideration as far as it fitting is the side to side measurement at the joint where the tie rod is attached to the rack.I know it sounds like a lot of trouble to replace the factory setup,but the feedback from the surface of the road and the overall feel makes it worth it.I also am trying to lose weight where possible ,because full tube chassis use up a lot my weight allowance.I'm already using a LS1 (highly modified)with a T56 manual trans and a three link rear suspension with as many lightweight components as possible,so as you can see weight everywhere is an issue.I say keep weight as low as possible when handling is the issue.Any info would be greatly appreciated.Thanks for your time.
