Results 1 to 9 of 9
Thread: Need help with pvc system
I am building a twin turbo big block chevy and I need to come up with a system for crankcase venting. First off my car needs to be roadworthy so I dont want to just run vent hoses down and get oil splattered all over, and with the turbo system there seems to be a few issues just using a regular pcv setup. I also need to relocate my pcv valve on the one cover as its in the way of an airfilter box I am using for the fresh air cowl induction system. So first off I need to drill a new hole in the valve cover and build some kind of a baffle under it. It would be nice to have screw in fittings that wont seep oil. Both valve covers need to be set up the same way. The I need some kind of a breather tank that the hoses can go into that would separate the oil and allow it to return to the pan. This kind of stuff is all new to me so I would appreciate someone pointing me in the right direction.
Thanks in advance,
Mike
