      New York, NY
      Electrical connections for engine break-in
      The engine/transmission is on the frame, no body or wiring harness yet.
      What electrical connections will I have to make to break-in the motor?
      It is a SBC, with HEI, 3 wire newer alternator, CS alternator, electric fuel pump, and electric fans.
      Does the alternator need to be hooked up, or do I just hook the battery to a charger?
      Here's what I was planning on:
      fuel pump directly to the battery
      electric fans directly to the battery
      HEI to the battery
      Starter to battery with jumper cables
      Water temp, oil temp, and tach to the battery
      Anything I'm missing here?
      Henderson,NV
      Fuses.
      Todd
      dayton, oh
      i would hook up the alternator... i'm not sure a battery charger would be able to keep up for 20 minutes or so...
      dave.t
      74 Javelin AMX - stocker
      New York, NY
      Will it be ok to not hook up only 1 wire in a 3 wire alternator?
      Also, one 8 gauge wire from the battery in the trunk will come to a junction block on the firewall, which will then go to the alternator and fuse block. I plan on using fusible link(s) to protect the main electrical wiring system. Do I use them for each link after the junction block or only use one coming right off the battery?
      i.e. one for alternator, one for electric fans, one for main fuse box etc.
      --or--
      just one from the battery before the junction
      Jerome
