      California
      Notching frame for wide tires?
      I have a few questions about notching the front subframe. I did a quick search and found this thread...:
      https://www.pro-touring.com/forum/sh...ht=frame+notch
      ...which shows it can be done, but I just want to ask a few questions for peace of mind. A couple months ago I put the ATS tall spindles on, along with the Touring Classics brake kit. My old wheels wouldn't fit, and I found a hell of a deal on some BMW M3 wheels in the for sale section. At first I just thought I'd buy them and use them until I found some better wheels, but they've grown on me and I'd like to keep them.
      I believe they're 18x8 up front, with around 6" of backspacing. I ordered a 1.25" adapter from Skulte, but had to get an extra 1/4" spacer for each side because the tie rods hit the wheels. Anyway, the problem areas are obviously the frame (in front of and behind the control arms) and the inner fenders (big enough bumps cause the tires to lightly rub the fenders). I'm not too worried about the inner fenders, though, since I figure I can just get some sheets of flat aluminum and make custom inner fenders, similar to the Chassisworks ones.
      Still, how hard is it to notch the frame? Would it detract from the structural integrity at all? I've never welded before, so would I be able to just cut some notches, drive it to a muffler shop and have them finish it for me? Or maybe I could rent a welder if it's cheap enough. In the link I posted, it looks like you basically cut a slit in the frame, push the metal in, and then get a small piece of metal and weld it in the open spot. Is that right? Should I maybe weld in some sort of bracing to keep the rigidity?
      Sorry for all the noobish questions, I just want to do this safely and correctly, so any advice or opinions would be greatly appreciated.
      Matt
      New York, NY
      I would take it to a shop to get it done. Mark up where you want it cut and welded, then take it to a race car or fabrication shop to get it done.
      If you've never welded before, this probably isn't where you should learn. You also probably shouldn't drive the car with areas around the front suspension pickup points cut out.
      It does take away some strength, because it makes the profile of the frame rail smaller.
      California
      Yeah that's what I was afraid of. Though I doubt it would really weaken it too much since I wouldn't be removing that much material.
      Does anyone know of any fabricators/race shops in the socal area? I know there's a BMW race shop somewhere around here but I don't know if they'd do it.
      Matt
      California
      Really? There's nobody in SoCal that can recommend some good places that would notch the frame?
      Matt
      Denton, Texas
      Those wheels look cool as hell on there, good luck finding a shop.
      Can't wait to see it with all 4 shoes on.
      ~Chris
      1973 Mustang SportsRoof
      Simi Valley, CA U.S.A.
      California
      Quote Originally Posted by Benoit23
      Thanks.
      Actually all 4 are on, but I have to make extremely wide turns (I can't even go in certain parking lots or parking structures if the lanes aren't wide enough) and it's really not fun to drive because of that.
      Quote Originally Posted by Lance-W
      That looks absolutely amazing, but like I said, I've never welded before, so there's no way mine would turn out like that.
      Anybody willing to do it for me in exchange for cash and beer and/or pizza?
      Matt
