Results 1 to 12 of 12
Thread: Burned Up Wire(s) - Need Help!
08-18-2008 #1
I was out cruising this weekend and all of a sudden I completely lost all electrical power. When I pulled over I noticed the wire coming from the positive terminal on the battery to the distribution block (where all electronics are wired to) was burned up and in half.
I replaced the wire from the positive terminal to the distribution block but I no longer have any power when I turn the ignition switch to on or start.
I am assuming I probably burned up the ignition wire - Am I correct here?
Here is my problem/question... I "think" the ignition wire runs from the ignition switch to the starter. I guess I need to crack open the dash and trace the wire through the car. Does anybody know where this wire runs? Does it come out the driver side firewall?
Any help on this would be appreciated. I suck with wiring and this is going to be a big headache for me. :\
