    Results 1 to 19 of 19
      Washington, MO
      What's considered a 'Fast' ratio box?
      My 79 Monte came with a box that was 3 turns lock to lock. I spent the time to put in a box from a Monte SS that I thought was 2.5 turns, but is more like 2.75 turns. However all was not lost, I replaced the factory tie rods, idler, center link, etc and I got the steering wheel to sit straight. Now all I need is to align this SC&C stage I package.
      Anyway, how many turns lock to lock is considered a 'fast' ratio?
      And of those, which ones would work for a G-body application?
      Washington, MO
      Bump, anyone?
      NW Burbs, IL
      Well, my chevelle came with a 14-16:1 box. I plan to upgrade to 12.7:1 at some point. I don't think I have seen one faster than 12:1.
      To calculate ratio: (Steering wheel turns lock to lock X 360°)/Pitman arm sweep = ratio.
      Nov 2007
      Afton,Mn
      to me it's not how many turns lock to lock but the ratio. I consider 12.7:1 a fast box.
      http://www.chevelles.com/techref/ftecref29.html
      here's fast http://www.sweetmfg.biz/products3.asp?edit_id=46
      NW Burbs, IL
      Quote Originally Posted by amx2334
      That is fast!
      NW Burbs, IL
      Quote Originally Posted by Tony_SS
      My 79 Monte
      Does your Monte have internal stops in the box? I know with my chevelle, it has stops on the steering arms, and an internal stop style camaro box will not give me the full pitman arm sweep, reducing turning radius.
      Something to keep in mind.
      Palm Beach Gardens, FL
      Here's some info I got from somewhere, sorry I can't give credit to who put it together. ...sorry for the long post also.
      GM/Saginaw quick-ratio steering box donor car cheat sheet
      Late Model 12.7:1 quick-ratio gearbox
      ID markings YA, WS and HX
      Line Thread Size: M18x1.5 and M16x1.5
      Number of Mounting Holes: 3, (missing leg H-pattern)
      Input Shaft Diameter: ¾-inch
      Output Shaft Diameter: 1 ¼-inch
      Number of Turns Lock to Lock: 2 ½ - 3
      1984-'88 Monte Carlo/Malibu with Z65 suspension
      1983-'88 Malibu, El Camino
      1982-'92 Camaro except FE1 soft ride suspension
      1984-'87 Regal with FE2 or FE3 sport suspension
      1983-'84 Hurst/Olds
      1985-'87 Cutlass with 5.0 (VIN code 9)
      1982-'85 Trans Am
      1986-'92 Firebird except FE1 suspension
      1986-'87 Grand Prix with FE2 touring or F41 heavy duty suspension
      Pre-'76 12.7:1 quick-ratio gearbox
      Line Thread Size: 11/16 x 18 and 5/8 x 18
      Number of Mounting Holes: 4, (H-pattern)
      Input Shaft Diameter: 13/16-inch
      1967-'76 Camaro, Firebird
      1970-'76 Monte Carlo/Malibu
      1964-'76 Chevelle
      1977-'79 12.7:1 quick-ratio gearbox
      Number of Turns Lock to Lock: 2 ½- 3
      1977-'79 Camaro, Firebird
      1977-'79 Monte Carlo, Malibu
      1977-'79 Chevelle
      Jeep/S-10 14.0:1 quick ratio gearbox
      Number of Turns Lock to Lock: 3 - 3 ½
      1991-'92 Fleetwood
      1992-'95 Grand Cherokee
      1984-'93 Comanche
      1984-'95 Cherokee/Wagoneer
      1983-'86 Bonneville
      1982-'93 2WD S-10 Blazer and pickup
      Weatherhead conversion fittings
      (from your local auto parts store)
      Part number M41157X6X16 - AN6 male to metric 16 O-ring male
      Part number M41157X6X18 AN6 male to metric 18 O-ring male
      Part Number 1446 - female inverted flare thread
      (5/8-18) to male 16 X 1.5 metric o-ring
      Part Number 1447 - female inverted flare thread
      (5/8-18) to male 18 X 1.5 metric o-ring
      Part Number 1444 - 11/16-18 thread O-ring
      Male to 5/8-18 female inverted thread adapter
      An easy way to upgrade the handling on your car is to convert to a quick-ratio power steering box. Many of these were original equipment on certain makes and models, and can be transplanted into many other vehicles, if you know what you're looking for at your local salvage yard or area swap meet.
      Early 1960s power steering gearboxes were originally manufactured with a wide turn ratio. Depending on the manufacturer, most were in the area of 16.0:1 to as high as 24.0:1, requiring a full four to five turns of the steering wheel to complete their range from lock to lock (wheels locked from the extreme right to the extreme left). These units were also designed with variable pressure, meaning they have slow steering response around the center point, but improved response as you approach the ends of their maximum range.
      With a little knowledge of the differences between power steering units, you can find adaptable quick-ratio gear boxes at your local pick-a-part that will have a more responsive lower ratio, as well as reduce the steering wheel range to as low as two to three full turns.
      The most popular gearbox used in GM, AMC and some Ford models was the Saginaw 800 box. Saginaw produced two different basic power steering units. In the 1960s and '70s, most Saginaw steering units produced were the model 800; the model 605 began appearing in mid-size GM vehicles in 1978. The easiest way to tell an 800-type gearbox from a 605-type box is by the type of Pitman cover on the shaft. Four bolts retain the 800-type cover, while the 605-type unit has a snap ring holding an inset Pitman cover. Both feature a nut in the center of the cover, which holds the Pitman splined output shaft in place. Aside from the mounting bolt pattern (some are four-bolt mount, and there are two different three-bolt mounts), the 800 units are all interchangeable. These 800-type units were found on the following cars:
      • 1964-'84 AMC full-size cars
      • 1968-'74 AMX
      • 1968-'74 Javelin
      • 1965-'91 Jeep J-series truck and station wagon
      • 1970-'88 Grand Prix and Monte Carlo
      • 1964-'88 GM A-body cars
      • 1967-'92 GM F-body cars (Camaro and Firebird)
      • 1964-'79 GM X-body cars (Apollo, Nova, Ventura and Omega)
      • 1964-'88 Chevy El Camino and GMC Sprint
      • 1972-'75 IHC Scout
      Saginaw 800 units were also used in some Ford products:
      • 1972-'79 Fairlane, Torino, Elite, Gran Torino and Ranchero
      • 1975-'79 Cougar
      • 1977-'79 LTD II and Thunderbird
      • 1973-'75 Montego
      • 1971-'73 Mustang
      • 1969 LTD
      • 1965-'69 Galaxie, Custom, Country Sedan and full-size cars
      • 1965-'66 Mercury full-size cars
      The standard 17.5:1 steering ratio (four turns lock-to-lock) was used on these units through the 1960s, but a more responsive 14.4:1 ratio (31/2 turns lock-to-lock) became the normal power steering ratio in 1970 on the full-size models.
      The 14.4:1 ratio replaced the earlier 17.5:1 ratio completely by 1973 for all body styles. Some 1967-'76 F-, A- and G-body Chevrolets also used a 12.7:1 (also 3½ turns), which will interchange as well. These 12.7:1 units are the most popular units for a quick-ratio conversion because of their ease of conversion into other models.
      A 14.0:1 unit, which was used on the two-wheel drive S-10 pickup and Blazer models from 1982-'93, will also interchange. You will also find these 14.0:1 ratio units on many Jeep models and some full-size GM cars. Another option is to use the even later model G- or F-body units. They were original equipment on 1983-'88 Chevelles and El Caminos, 1984-'88 Monte Carlos, 1983-'84 Hurst/Olds, 1985-'87 Olds 442s, and 1984-'87 Buick Grand Nationals or T-Types. They are 12.7:1 units, however, and they're not easy to find, as they were used on performance suspension options in many applications. They can be identified by a "YA," "WS," or "HX" marking on the end cap opposite where the steering column attaches. These units will reduce steering wheel revolutions from lock to lock down to 2¼ to 2¾ turns.
      An important thing to remember when interchanging these gearboxes is to retain and use your original Pitman arm and idler arm to keep front-end geometry to specification. Different body styles have different length arms: The F-Body arms are longer than the A- or G-body parts, and using the wrong Pitman and idler arms could cause inner fender well clearance problems, if used in different body styles.
      When interchanging between earlier and later GM gearboxes, the power steering hose fittings are not the same. Later fittings are metric (16mm or 18mm, instead of 5/8-inch and 11/16-inch inverted flare fittings) and also incorporate an O-ring for better sealing of the fittings. Auto parts stores sell adapters to accomplish this changeover, whether converting the metric thread back to inverted flare so you can use your original hoses, or converting to A-N type fittings so you can have new hoses made. The rag joint or steering gear coupler may also have to be changed, depending on shaft size; these can be obtained with the gearbox when pulled from the donor car, or can be purchased new from most auto parts stores or any GM dealership. The coupler off an early 1980s Chevy pickup works just fine to adapt the early-style steering shaft to the later model gearbox (GM part number 7826542).
      The mounting pad on these units where the box bolts onto the frame can be in a four-bolt H-pattern, a three-bolt pattern similar to the H-pattern but without the lower left bolt hole, or a three-bolt Y-pattern, in the case of the Fords. The four-bolt H-pattern and the three-legged H-pattern will interchange for mounting purposes, though an adapter plate would be necessary to mount these units to the Ford Y-pattern mounting.
      As with all conversions we feature in this column, we recommend you carefully inspect your donor gearbox to make sure all splines are in good shape and the unit doesn't leak. If it does, now would be a good time to throw a Pitman shaft seal kit into it while you have it out. They are pretty cheap insurance at about $25; these units can be pretty heavy when putting them in and taking them back out again, so you don't want to install them more than once.
      Fords present a unique problem, because both Ford's own manual and power steering gearboxes were the same gearbox until the mid-to-late 1960s. Ford's power steering consisted of the manual gearbox with a control valve attached to the end of the center link and a power cylinder, similar to a hydraulic shock absorber or ram unit. These gearboxes were available in 16.0:1 or 20.0:1 ratios, and in either a 1-inch or a 1-1/8-inch steering shaft diameter. Units on some models from 1964-'67 still incorporated the long steering shaft that went up inside the steering column. The same type of unit was used in the earlier Fords of the 1950s and early '60s with non-collapsible steering columns. The later Ford units used a separate steering shaft and rag joint-type coupler set-up from 1967 on, similar to the GMs.
      Ford used both its own units and Saginaw gearboxes on various models from 1965-'79, as you can see from the chart of Saginaw donor cars. So, a visual inspection of your unit could reveal your Ford can benefit from the use of one of the GM quick-ratio boxes as well. A two-bolt Pitman cover identifies the Ford units, whereas the Saginaw units were same as the 800-type units on the GMs and used the four-bolt Pitman cover.
      If you have a Ford type unit, you could interchange between the 16.0:1 (3¾ turns to lock) and 20.0:1 units (4-5/8 turns to lock), if the shaft diameters are also the same; however, the only way to change to a ratio smaller than 16.0:1 would be to have your own unit rebuilt by a steering box rebuilding specialist. There are several advertisers listed in this issue who can do this conversion.
      Some Mustangs and Cougars (power equipped in 1965-'66 and 1971-'73 and manual boxes from 1967-'73) can be made to handle a smaller ratio box by installing a Shelby Quick Steer kit, which uses a longer Shelby manual steering Pitman and matching idler arm. These are available from most of the Mustang suppliers. For Ford models other than the pony cars, you would need to send your gearbox out to one of the rebuilders who perform quick ratio conversions.
      Mopar gearboxes from 1966-'74 only came in two ratios: The manual steering gearbox was a 24.0:1 ratio with a radius of five and a third turns of the wheel, while the power steering boxes came in 15.7:1 and three and a half turns of the wheel. Manual gearboxes can be adapted to a quicker 20.0:1 ratio with the purchase of an aftermarket worm gear and shaft assembly from Mopar Performance parts (part number 4007612). Gearbox rebuilders can also install this unit for you.
      The only Mopars with a quicker ratio gearbox were the 1970-'71 AAR and T/A models, but your chances of finding a unit in a salvage yard for these cars is almost zero. Using the conventional 15.7:1 ratio power steering box with an extended Pitman arm and idler arm can provide a similar effect in the handling. Although the T/A or AAR Pitman will not fit the common gearboxes, you can get extended length components from aftermarket supplier Firm Feel Suspension. These are available for all popular A-, B-, C-, E- and F-bodies. The added length, as with the Shelby Quick Steer kit, effectively adds to the response of the steering system, serving roughly the same purpose as modifying your existing gearbox or browsing through the salvage yard for the quicker steering unit. Dart and Valiant A-bodies from 1964-'72 would require changing to a later 1973-'76 A-body center link, as well as the longer Pitman and idler arms to maintain the proper steering geometry.
      When you locate an acceptable used unit, you can expect to pay between $75 and $200 for the earlier 12.7:1 ratio box and between $125 and $250 for one of the later 14.0:1 ratio units. Many auto parts stores also sell these boxes on an exchange basis in the $185 to $225 range, but expect to pay a core charge penalty if you are not trading in a unit or if the trade-in is not the same as the unit you are purchasing. Considering that many aftermarket companies are selling quick-ratio units in the $450 to $539 price range, you can see why spending a little time at your local salvage yard is well worth the effort.
      Completing an upgrade to a quick-ratio steering gearbox or using longer arms to make your car feel like it has a quicker ratio steering box will add handling characteristics to your car's steering, as well as reducing the driver's effort by enabling the steering wheel to be more responsive to small changes in direction.
      Here's some good info on modifing the ps pump when switching boxes.
      HERE
      Washington, MO
      Quote Originally Posted by bochnak
      No I dont think so. No external stops either. I guess the 12.7:1 is not so bad. I did read of a 12:1 in the F-bodies and that would have been nice, but I can live with the 12.7 ratio.
      NW Burbs, IL
      Quote Originally Posted by tiek1011
      HERE
      Great info. I'll have to keep this in mind when I get to that point.
      Jun 2002
      Benicia, CA
      Back in the late-80's I installed an IROC steering box, and have 2.25 turns lock-to-lock. I was going to have my nabnual box rebuilt by a guy that built boxes for Nascar and other race divisions. He told me the best way to get the ratio with the relative feel of my manual was to get the IROC box, had to be from an IROC that had the special option fast ratio box.
      Found one at a local boneyard for $125 on a low-mileage car that had been wrecked in the rear. Had a hose built for standard on one end and metric on the other for $20. Was able to use my stock pitman arm. The box works beautifully!
      Jeff
      1971 RS Camaro: PAINKILLER
      OC CA
      Another thing to consider is how you will use the car. A fast box will be great for auto-x or short tracks, but may be quite a handfull when highway driving as more steering corrections are required to keep the car going straight. And, the fast box will exagerate any wandering tendencies the car may already have. IMO, not a deal breaker for the 12:1, but something to be aware of.
      I'm using a 14:1 ratio, and it seems to be a good compromise.
      Mark
      LS1- T56
      under construction
      "Political Correctness is a doctrine, fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
      Feb 2008
      Sesser, Il
      I have an XH Iroc box on my Cutlass and reused the f-body pitman. It was, at the time, a daily driver and I didn't think it was too quick at all. Also used the Iroc springs (new - Moog 5662) and the Iroc swaybar (hollow 36mm).
      I was told the XH box came on the Iroc's with the 16" wheels and had a tighter road feel than the YA box which came on the Z/28's with the 15" wheels which had a more normal passenger car feel. I couldn't tell you how many turns lock-to-lock as my car is presently awaiting an engine rebuild...
      Doug
      Doug Gulley
      Nov 2007
      Pittsburgh,pa
      Not to change the subject but I have a 71 nova, I started the project and had almost 5 turns lock to lock. I switched to the short steering arms and the long idler and pitman. I now have 2 turns lock to lock. Is there a difference between changing components and changing the steering box? If so what ratio box do I go with?
      Feb 2008
      Sesser, Il
      David Pozzi has a bunch of good info for F-bodies concerning steering and suspension that should also work good with your Nova. Look under first gen suspension.
      http://www.pozziracing.com/
      Doug
      Doug Gulley
      NC, in a house.
      Anyone have any info on increasing the road feel, or "stiffness" of the box with the torsion bar? I made a hybrid 12.1:1 box out of three others (race unit w/ broken case, Jeep XJ case and Monza spool valve) and with the stock spool valve/torsion bar it has stupid easy handicapped style steering.
      Which cars had the heavier steering?
      Central CA USA
      Tony,
      You got that from Hemmings: http://www.hemmings.com/mus/stories/...feature21.html
      Nov 2007
      Afton,Mn
      For the list of cars with what torsion bar go here.http://www.chevelles.com/techref/ftecref29.html
      scroll down to the links click on the spreadsheet.
      NC, in a house.
      Great info. Thanks!
