Thread: Clutch not disengaging
08-15-2008 #1
- Dec 2005
- 161
Can't seem to figure it out... I've just put a new motor in my car and am using the same clutch set up, but I can't seem to get it to disengage..
I've already pulled the motor to check if the disk was in backwards... and it wasen't.. but i still went ahead and started all over.. and same result... It goes past 'the hump' feel in the pedalbut i still can turn the driveshaft with it in gear and clutch in...
Is it possible the plate broke as i was re installing it? cuz it worked fine before..
ideas?The Gutless Cutlass, is no more.
'73 Chevy C10, Low with lots of GO!!!!
08-18-2008 #2
- Dec 2005
- 161
problem solved... fired it up in gear with the clutch in payed around with it... and it works minty...
one day too late though.. =(The Gutless Cutlass, is no more.
08-18-2008 #3glad yours was simple! I once glued a clutch to the flywheel with locktite that had seeped out of the bolt holes.... that took a few days to figure out!! lol
1967 Camaro - Done!
1968 Camaro - Underway
