Thread: getting new toy/project
- Dec 2007
- 91
- some stuff the car has with pic's
- SRP Flat Top pistons
- Scat I beam rods
- Stock Polished Crank
- AFR 185 cc heads 58cc combustion chambers
- Crane Gold Roller rockers
- TFS Push Rods
- Holley Systemax II intake
- Custom Comp Cams Hydraulic Roller Cam
- Mac 1 3/4 ceramic coated long tube headers
- 3" H Pipe, 3" flowmasters, 3" tail pipes
- BBK 70mm throttle body and EGR spacer
- 42 lbs injectors
- Aeromotive fule regulator
- PMAS 80mm Mass air
- AFM PMS, Series 4
- Vortech V2 supercharger 2.95 blower pulley 6.87 crank pulley, 10 rib
- AFM power pipe
- Snow performance methanol injection
- Holley 2551ph fuel pump
- T Rex in line fuel pump
- Fluidyne radiator
- Edelbrock high volume water pump
- Summit SFI balancer
- Taurus 2 speed electric fan
- Tremec TKO 500
- Centerforce dual friction clutch
- FRPP aluminum drive shaft
- 3.73 gears
- Tubular frame connectors
- UPR rear upper and lower control arms
- Rear coil overs w/ lakewood shocks
- UPR Tubular K member w/ A ar,s and coil overs
- KYB struts
- Maximum motorsports caster camber plates
- UPR bump steer kit
- SN95 front brakes
- FR500 wheels 17X9, 17X10.5
- MT et street radials
- Moser 35 spline axles, c-clip eliminators & spool
- Aerospace Rear Prostreet disc brakes
- Cobra Master Cyclinder
- Rollbar - Powder coated to match interior
- Impact 5 - Point Belts
- battery relocated to trunk - master disconnect switch installed
08-15-2008 #2
- Dec 2007
- 91
93 mustang coupe
08-15-2008 #3I'm not a ford guy but for some reason I like the notch backs...haha
08-15-2008 #4
- Dec 2004
- North Jersey
- 983
Very nice! Even though I'm a Chevy guy, that's exactly how I've dreamed of building a notchback Stang. Very subtle, and very cool. Good luck with it!
Steve Ragusa - North Jersey
2006 Infiniti G35x
08-15-2008 #5
