      Feb 2002
      Santee, CA
      Which heads for 396
      I'm building a 396 for my 66 El Camino and need some help selecting heads.
      Here's the configuration...
      • 1966 4-bolt main 396 (3855962) bored .070 over (same as a .040 over 402)
      • Keith Black KB160 Dome Pistons (Bore: 4.165 in., Piston Style: Dome, with two valve reliefs, Compression Distance: 1.765 in., Dome Height: 0.180 in., Piston Head Volume: -17.00cc )
      • Edelbrock Performer RPM Cam
      I'm leaning towards the Edelbrock Performer RPM Heads and intake, but would like to get somewhere around 9.5:1 compression.
      I used some online CR calculators and they are telling me that with a 110cc head, I am looking at close to 14:1! Ouch....am I doing something wrong?
      Any recommendations for heads, rockers, etc.?
      Eric Senior
      - 1966 El Camino SS396
      - 1969 Pro-Touring Camaro
      - 1970 Chevelle SS502 Convertible
      Have you allowed for head gasket thickness?
      Feb 2002
      Santee, CA
      I've checked a couple of online calculators. The last one I tried was http://www.csgnetwork.com/compcalc.html
      When I use a thick gasket (Felpro - .053), I get a 13.6:1 CR with a 110cc head
      Am I entering something wrong? Here's the data....
      Stroke = 3.76 in
      Bore = 4.164 in
      Gasket Bore Dia = 4.52 in
      Gasket Thickness = .053 in
      Head combustion chamber = 110 cc
      Piston Dome Volume = 17 cc
      Piston Deck Clearance = -.18 in
      Specs for the pistons can be found at :
      http://kb-silvolite.com/performance.php?action=details&P_id=105
      Detroit Subs
      You may be interested in the Dart Pro 1 275cc oval port aluminum head. It has 120cc open style chambers. Those Edelbrock heads have a chamber that is sorta open / sorta closed and can cause piston to head clearance issues with most of the commonly used aftermarket pistons.
