Results 1 to 9 of 9
- Jan 2008
- 86
Help solve my drum/disc incompatibility--what MC?
Sorry for the repeat post--I thought I was able to modify title to get to my point but it stayed the same as my original, so here is same ? w/correct title.
I have a 71 Cutlass that I converted from stock 4 wheel drums to camaro 11 in disc brakes w/f-body spindle and MC many years ago, but I did not change the proportioning valve (not necessary). I later upgraded to the "poor man's disc" rear from MP Brakes (11 in drums, big improvement) and that really helped the brakes. So I then decide to upgrade the front single piston Camaro calipers to the Stainless Steel brakes "quick change" dual piston caliper. After that swap the brakes barely worked at all. Neither MP nor SS Brakes were helpful at resolving incompatability; many of the website discussions suggested piston area differences caused the problems. I got frustrated and just put the single piston calipers back on and brakes are fine.
Hoping I can get some more specific feedback on what I need to do to make the dual piston SS front calipers work on my Cutlass. What Master Cylinder do I need (currently have the mid-70s Camaro disc/drum MC)? Do I also need to change the drum proportioning valve? If so, can I just put a stock disc proportioning valve or must I get an adjustable one? Thanks for any specific feedback. I'm betting the tech advice here is probably better than I was able to get from SS or MP Brakes!
TIA.
