      Eastern Virginia
      Wiring a MSD 6AL?
      Power to it, do you wire it hot all the time, or hot only with ignition on, does it matter?
      Scot
      86 Monte SS
      north central Iowa
      http://www.msdignition.com/uploadedF...structions.pdf
      the large black and red wires go directly to the battery and the small red connects to an ignition source.
      Eastern Virginia
      That is how I wired it, I didn't know if the red needed to be switched.
      thanks.
      Scot
      86 Monte SS
      north central Iowa
      Quote Originally Posted by Samckitt
      thanks.
      it should be correct then, are you having problems with it or just making sure it's correct?
      Eastern Virginia
      No problems, just making sure it is correct.
      Scot
      86 Monte SS
