      Eastern Virginia
      Oil pressure port question....
      I had to move my oil pressure sending unit from down near the filter up to the port at the back of the block behind the intake. Correct me if I am wrong, but the pressure should be the same at both places, right?
      The reason I ask is because I changed to a high volume pump & if I remember correctly I changed the oil pressure sending unit because the old one got broke, now when I start the motor the gauge is pegged as far as it will go, past 60psi. I think something is wrong. What do you think?
      Scot
      86 Monte SS
      Aug 2001
      Wilton, CA. (Sacramento)
      pressure should read the same either place. What kind of gauge do you have, mechanical or electric?
      Jody
      Eastern Virginia
      Quote Originally Posted by camcojb
      Jody
      Factory electric.
      Scot
      86 Monte SS
      Oct 2007
      ridgefield ct
      i had the same problem at one point when i ordered the sender by what the engine was. when i went to an 87 monte sensor it worked right (but i did have to clearence the intake to get it to fit).
      Eastern Virginia
      I bought the sender for the year of car, not motor.
      Scot
      86 Monte SS
      Oct 2007
      ridgefield ct
      guess i'm the only idiot then huh? damn!
      i'd buy/borrow an oil pressure gauge and test the top port (maybe the side port too). if they don't agree, warranty the sender.
