      Jun 2006
      southern connecticut
      narrowed rearend advice needed
      hey guys, i'm about to start the body work on my Nova... the DSE minitub kit is going to be installed and was looking into purchasing a new rear end through moser, the housing and axle package. my question is should i have them narrow the axles and housing for use with the mini tub kit? and if so, what would be the appropriate amount to have taken off? or should i not even bother having them narrow it?
      also, does anyone recommend a different company to purchase the 9inch rear from?
      thanks in advance guys, photos will be provided as the body is starting to come together! -Rich
      Aug 2003
      We sell more Mosers then anyone to the Pro Touring crowd. Give us a call, you will save a few pennies and get all the measurements you need.
      four zero seven 832 1752
      8AM to 10PM eastern time
      May 2002
      Northern California
      Yep give frank a call , he knows the measurments you will need.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Dec 2007
      British Columbia, Canada
      x2 on giving Frank a call. Great guy to deal with. If you don't have your wheels yet, you'll want to get them, mock them up in place and then measure from there. That way you're fitting the rear end to the wheels and don't have to worry about backspacing.
      Jun 2006
      scherp, good thinking with mocking the wheels up first, that would be much easier that way, and Frank, i'll def. be giving you guys a call to order up that rearend. thanks guys! -Rich
