      Connecticut
      Powder Coat Question
      i am going to have my chris alston camaro front clip powder coated. the guy that is doing it said that he can plug all the holes but doing that leaves a little build up around each plug. he suggested just retaping the holes after. what do you guys think is best.
      thanks
      Midwest
      I'd leave the holes open and re-tap them later. It's a little bit of a hassle, but it comes out nice and clean.
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      New York, NY
      on the other hand, he should try to keep sand out of the threads, cause you will break taps and want to kill him if there is sand stuck in the threads.
      connecticut
      Quote Originally Posted by jerome
      he's right when they sandblast the hole it makes a mess . i used short set screws in the holes to plug them just below the surface.
      Connecticut
      good to know so would you say i should put in the set screws for the sand blasting and then remove them for the powder coating? thanks again Paul
      Paul,
      Did you get the frame done yet?
      Dave
      Connecticut
      not yet, been way to busy at work. looking to do it by the end of the month.
