      May 2001
      Mesa, Az.
      Bandsaw Blad MFG???
      Which bandsaw blade brands are you favorite?????
      I have tried the Lenox blades and weren't very happy with the quality of the weld or the blade. Especially for the 30 or so dollars they were a piece.
      What are some other brands??
      Mar 2004
      Mid-Michigan
      I use Morse blades purchased through Enco.
      Follow the link...
      http://www.use-enco.com/CGI/INSRHI?PMSECT=0000000689
      The last time I bought blades 2 yrs ago they were on sale for 5 or 6 bucks apiece. I stocked up big time and have only changed blades once since then...
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      May 2001
      Mesa, Az.
      Thanks!
      St. Pete FL
      Try Morse or Simonds. Also, Fastenal will make you one from coil stock to any size.
      HELP!!!
      Rockford Illinois
      DoAll also makes some really good blades. They have a multitooth blade that will save a bunch of time and extra blades to do the jobs that are different in thickness without changing blades.
      You can get DoAll blades thru Grainger.
      Morse also, found them on ebay for a good price.
      Mar 2010
      GR Michigan
      Check Production Tool, they have several outlets. Get a couple bi-metal blades with 18-24 teeth for thin material and 10-12 teeth for thicker material. If you cut wood or aluminum use a 6-8 tooth (1/4" or thicker)
      Jeff
      73 Mustang Convertible
