    Results 1 to 10 of 10
      Heidts front sub Frame
      Hey Guys,
      I need your advice. I am installing a Heidts complete front sub frame assembly with power rack and pinion steering on my 69 camaro, I am installing a new LS376 from GM Perf Parts. I need to know if anyone knows, what headers, motor mounts and oil pan to use.
      Auburn, WA
      Did you call Heidts?
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      La La Land, CA
      My suggestion is to buy a tape measure. Then you can tell all of us who don't run that frame what works. You are not going to find very many people who own that frame here. I second Matt's statement of calling the manufacturer and ask them what works in their product.
      Good luck.
      Tyler
      Quote Originally Posted by TitoJones
      Good luck.
      Tyler
      dont bother ...last time we called heidts they didnt even know what would work and what didnt....and this was for a more common big block chevy...just my 2cents!
      Yukon, OK
      I've got an LS1 mounted to that subframe right now. I used some $45 ebay motor mount adapter plates(heavy plate steel). My stock camaro oil pan fits perfect. All my stock camaro accessories fit too, including a/c. I'm going to be ordering S&P or Hooker headers soon. My only worry is the steering shaft, but I won't know how much of an issue that will be until I get my headers. Good luck with it!
      And yes, heidt's is pretty clueless on what parts to use. Unless it's a sbc of course.
      Quote Originally Posted by CamaroLance
      You put a 1st Gen stock oil pan on your LS motor and installed it in a Heidts new subframe? Please let us know how the headers fit when you get them. Do you have any pictures.
      Mountain Springs, Texas
      Quote Originally Posted by THE PEARL CYCLONE
      I think he means the stock 4th Gen F body LS1 oil pan.
      Don
      Auburn, WA
      I think he means a stock LS1 Camaro pan, straight from a 4th gen. 1st gen pans require a bit of RTV to fit on an LS.
      Matt Jones
      Mechanical Engineer
      Oct 2006
      Phoenix, AZ
      Quote Originally Posted by silver69camaro
      ROFLMAO, Classic, truly Classic.
      Jeff K.
      69 Camaro SS, 406 SBC, TKO600, 9" w/3.73 tru-trac, Speedtech Arms, AFX Spindles, Lee 670 Box, Baer GT front, C5Z rear. Hyperco Leafs w/ Fays2 Watts Link + Varishocks.
      Yukon, OK
      hehe... YES YES... 4th gen LS pan!! However, I could probably get a sbc or bbc pan on there with a big enough hammer.
